Introduzione
Before you begin the LCD Screen Display replacement process, be sure to ground yourself. Grounding yourself prevents short circuiting the device, and/or shocking yourself. An easy way to do so would be to remove one of your shoes.
Strumenti
Ricambi
Nessuna parte specificata.
Remove the plastic trim at the base of the screen screen. Start from the tab on the right side and work to the left side.
Remove 2 M2x3mm screws that are located at the bottom of the plastic bezel with a PH0 screwdriver.
Altre 2 persone hanno completato questa guida.
