Salta al contenuto principale
Dell XPS M170 MXG051 Memory Module Replacement
Cosa ti serve
  1. Dell XPS M170 MXG051 Memory Module Replacement, Dell XPS M170 MXG051 Battery Removal: passo 1, immagine 1 di 1
    • Turn off your computer. Then, disconnect your computer and all attached devices from their electrical outlets.
    • Close the display and turn the computer upside down on a flat work surface.
    • Slide the battery-bay latch release on the bottom of the computer and remove the battery from the bay.
  2. Dell XPS M170 MXG051 Memory Module Replacement, Remove Memory Module Cover: passo 2, immagine 1 di 1
    • Loosen the two captive screws from the memory module cover, and remove the cover.
  3. Dell XPS M170 MXG051 Memory Module Replacement: passo 3, immagine 1 di 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module(s) from the connector at a 45 - degree angle.
  4. Dell XPS M170 MXG051 Memory Module Replacement, Install New Memory: passo 4, immagine 1 di 1
    • Align the notch in the new memory module's edge connector with the tab in the connector slot.
    • Slide the module firmly into the slot at a 45 - degree angle, and press the the module down (so that it is horizontal. If you do not feel the memory module click into place after you press it down, remove the module and reinstall it.
  5. Dell XPS M170 MXG051 Memory Module Replacement: passo 5, immagine 1 di 1
    • Replace the memory cover and tighten the captive screws.
Linea Traguardo
Johnathan Hammond
Membro da: 02/28/18
45.237 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
43 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 112
