Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
How to replace the memory modules of a Dell XPS M170 MXG051.
Parti
Nessuna parte specificata.
  1. Turn off your computer. Then, disconnect your computer and all attached devices from their electrical outlets.
    • Turn off your computer. Then, disconnect your computer and all attached devices from their electrical outlets.
    • Close the display and turn the computer upside down on a flat work surface.
    • Slide the battery-bay latch release on the bottom of the computer and remove the battery from the bay.
  2. Loosen the two captive screws from the memory module cover, and remove the cover.
    • Loosen the two captive screws from the memory module cover, and remove the cover.
  3. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module(s) from the connector at a 45 - degree angle.
  5. Align the notch in the new memory module's edge connector with the tab in the connector slot.
    • Align the notch in the new memory module's edge connector with the tab in the connector slot.
    • Slide the module firmly into the slot at a 45 - degree angle, and press the the module down (so that it is horizontal. If you do not feel the memory module click into place after you press it down, remove the module and reinstall it.
  6. Replace the memory cover and tighten the captive screws.
    • Replace the memory cover and tighten the captive screws.
Linea Traguardo
Johnathan Hammond
Membro da: 28/02/2018
36.530 Reputazione
408 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
18 Membri
1.816 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 45
