Salta al contenuto principale
Dell XPS M1530 Wireless Card Replacement
Cosa ti serve
  1. Dell XPS M1530 Wireless Card Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Wireless Card Replacement: passo 2, immagine 1 di 1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Wireless Card Replacement: passo 3, immagine 1 di 2 Dell XPS M1530 Wireless Card Replacement: passo 3, immagine 2 di 2
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 1
    • Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
    • Two 4.7mm Philips #1 screws
  5. Dell XPS M1530 Wireless Card Replacement: passo 5, immagine 1 di 2 Dell XPS M1530 Wireless Card Replacement: passo 5, immagine 2 di 2
    • Lift the panel up from the indented area.
    • This indent should provide enough grip to remove the panel with ease.
  6. Dell XPS M1530 Wireless Card Replacement: passo 6, immagine 1 di 1
    • Remove the single 3.9mm Phillips #1 screw in the upper right corner of the wireless card.
    • One 3.9mm Phillips #1 screw
  7. Dell XPS M1530 Wireless Card Replacement: passo 7, immagine 1 di 1
    • Lift the card out at an angle and carefully remove it.
  8. Dell XPS M1530 Wireless Card Replacement: passo 8, immagine 1 di 2 Dell XPS M1530 Wireless Card Replacement: passo 8, immagine 2 di 2
    • Use a spudger to carefully disconnect the antenna cables from the card by prying them straight up off the board.
    • It's best to use an ESD-safe tool, such as a nylon spudger, rather than the metal spudger shown in the photo.
    • Note the order of colors for the antenna cables indicated on the card.
Conclusione
Jase Sasaki
Membro da: 01/22/15
721 Reputazione
5 Guide realizzate
Cal Poly, Team 18-4, Maness Winter 2015 Membro di Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,801
