Salta al contenuto principale
Dell XPS M1530 Hard Drive Replacement
Cosa ti serve
  1. Dell XPS M1530 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Hard Drive Replacement: passo 3, immagine 1 di 2 Dell XPS M1530 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 2 Dell XPS M1530 Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 2
    • Remove the four Phillips #1 screws holding the Hard Drive in place.
    • Four 3.5mm Phillips #1 screws
  5. Dell XPS M1530 Hard Drive Replacement: passo 5, immagine 1 di 2 Dell XPS M1530 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Pull the Hard Drive out gently using the tab. It should provide enough leverage to pull the drive out smoothly.
  6. Dell XPS M1530 Hard Drive Replacement: passo 6, immagine 1 di 2 Dell XPS M1530 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Remove both 3.5mm Phillips #1 screws on either side of the plastic casing.
    • There is a second screw on the other side of the casing.
    • Then gently separate the drive from its casing.
Conclusione
Tyler Scholz
Membro da: 01/22/15
479 Reputazione
3 Guide realizzate
Cal Poly, Team 18-4, Maness Winter 2015 Membro di Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,044
