Introduzione
This guide will demonstrate how to replace the Dell XPS M1330’s RAM.
Turn the computer over and loosen the three captive screws and the M2.5 x 5-mm screw. Remove the module cover.
Remove the module from the connector.
Align the notch in the module edge connector with the tab in the connector slot.
Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
Replace the module cover.
Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
Turn on the computer.
