Salta al contenuto principale
Dell XPS M1330 CPU Replacement
Cosa ti serve
  1. Dell XPS M1330 CPU Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop on its back, so that the underside is facing up.
  2. Dell XPS M1330 CPU Replacement: passo 2, immagine 1 di 1
    • Push and hold the slide button to the left and unlock the mechanism.
  3. Dell XPS M1330 CPU Replacement: passo 3, immagine 1 di 2 Dell XPS M1330 CPU Replacement: passo 3, immagine 2 di 2
    • Lift the computer up and slowly pull the battery straight out from the device.
  4. Dell XPS M1330 CPU Replacement, Fan: passo 4, immagine 1 di 2 Dell XPS M1330 CPU Replacement, Fan: passo 4, immagine 2 di 2
    • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
    • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
    • Remove the fan cover.
  5. Dell XPS M1330 CPU Replacement: passo 5, immagine 1 di 1
    • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
    • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
  6. Dell XPS M1330 CPU Replacement: passo 6, immagine 1 di 1
    • Be sure to carefully remove the wires as they are fragile and can rip easily.
    • Remove the wire bay near the fan.
    • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
    • Gently pull upward while moving your hand side to side so the plastic holder will detach.
  7. Dell XPS M1330 CPU Replacement: passo 7, immagine 1 di 1
    • Gently remove the fan and its attachments from the bay.
  8. Dell XPS M1330 CPU Replacement, CPU: passo 8, immagine 1 di 1
    • Using the flathead screwdriver, turn the one screw counterclockwise to loosen the CPU, but do not remove the screw.
  9. Dell XPS M1330 CPU Replacement: passo 9, immagine 1 di 1
    • Using the iFixit opening tool, prop up the CPU.
  10. Dell XPS M1330 CPU Replacement: passo 10, immagine 1 di 1
    • Carefully lift the CPU away from its housing.
Conclusione
Kai Kapossy
Membro da: 03/24/19
676 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 636
