Salta al contenuto principale
Dell XPS 9720 Battery Replacement
Cosa ti serve
  1. Dell XPS 9720 Battery Replacement, Remove back cover: passo 1, immagine 1 di 1
    • Remove 8 T5 screws. Use an opening tool to pop open the plastic tabs that hold the aluminum and plastic halves of the shell together. Begin by inserting the tool at any point, then sliding it around the perimeter of the device to release all of the tabs. There are no tabs along the hinge side of the device.
  2. Dell XPS 9720 Battery Replacement, Unplug the battery: passo 2, immagine 1 di 2 Dell XPS 9720 Battery Replacement, Unplug the battery: passo 2, immagine 2 di 2
    • Place a finger through the plastic loop attached to the battery plug, and pull firmly away from the motherboard.
  3. Dell XPS 9720 Battery Replacement, Remove battery screws: passo 3, immagine 1 di 2 Dell XPS 9720 Battery Replacement, Remove battery screws: passo 3, immagine 2 di 2
    • Unscrew the 7 PH1 screws retaining the battery.
    • The battery can now be lifted from the chassis.
    • Reverse the steps to install the new battery.
Conclusione
Sebastien Bolle
Membro da: 09/12/15
326 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 47
Tutti i Tempi: 878
