Cosa ti serve
Flip your device the other way around
Don't be confused that this device is black, its a skin
Grab your T5 Torx and identify the 10 torx screws
Make sure that this is a T5, to not strip the screws. They can be very difficult to remove
Careful there are more screws, do not try to open yet!
Open the flap on the back of the laptop
There are two screws that need to be removed, please use a Philips 0 screwdriver
The backplate might not be easy to open
You can use a soft prytool to open the laptop easier
Don't insert the tool too deep or you might break the mainboard
Now, you should be able to remove the backplate
Locate the battery connection to the mainboard
Unplug the battery before doing anything else
You can use a pry tool to make this easier
Locate the SDD on the mainboard
Use a Philips 0 to remove the screw of the SDD
Slide the SSD out of its socket.
Try not to lift the SSD any more than necessary
During reassembly, make sure the slot in the SSD lines up with the slot in its socket. Do not touch the gold-colored contacts with your fingers.
Reconnect the battery and reassemble
Altre 3 persone hanno completato questa guida.
