Salta al contenuto principale
Dell XPS 720 H2C Memory Modules Replacement
  1. Dell XPS 720 H2C Memory Modules Replacement, Removing Dell XPS 720 H2C Cover Panel: passo 1, immagine 1 di 2 Dell XPS 720 H2C Memory Modules Replacement, Removing Dell XPS 720 H2C Cover Panel: passo 1, immagine 2 di 2
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
  2. Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: passo 2, immagine 1 di 3 Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: passo 2, immagine 2 di 3 Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: passo 2, immagine 3 di 3
    • The memory modules are located directly above the XPS processor and are attached to the motherboard.
    • There are notches securing the memory modules onto the motherboard.
    • Push down and outward on the both notches to release each memory module from the motherboard.
  3. Dell XPS 720 H2C Memory Modules Replacement: passo 3, immagine 1 di 1
    • Carefully remove each memory module from its slot.
    • If you are reseating the memory modules, this is the time to clean them and make sure there isn't any dust build up on the surface.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 4-16, Maness Spring 2013 Membro di Cal Poly, Team 4-16, Maness Spring 2013
CPSU-MANESS-S13S4G16
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,221
