Introduzione
A hard drive is a magnetized storage area. Your Operating System is stored on your hard drive, as well as all your software programs. This guide will instruct you on how to take the hard drive out of the computer so that you may replace or repair it.
Parti
Nessuna parte richiesta.
Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
  • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
Aggiungi Commento
The hard drive is located  the top-center area of the computer.
  • The hard drive is located the top-center area of the computer.
  • Carefully disconnect the data and power cables from the hard drive.
Aggiungi Commento
  • Push the tabs on both sides of the hard drive bracket towards each other and slide the hard drive up and out of the hard drive bay.
Aggiungi Commento
  • Unscrew the four 5mm screws on both sides of the hard drive using the Phillips #1 screwdriver and then remove the hard drive from the case.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Graham Bultema
Membro da: 17/04/2013
67 Reputazione
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,244
