Salta al contenuto principale
Dell XPS 18 Touch Control Board Replacement
Cosa ti serve
  1. Dell XPS 18 Touch Control Board Replacement, Back Cover: passo 1, immagine 1 di 1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Touch Control Board Replacement: passo 2, immagine 1 di 1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Touch Control Board Replacement: passo 3, immagine 1 di 1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Touch Control Board Replacement, Internal Cover: passo 4, immagine 1 di 1
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Touch Control Board Replacement: passo 5, immagine 1 di 2 Dell XPS 18 Touch Control Board Replacement: passo 5, immagine 2 di 2
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Touch Control Board Replacement: passo 6, immagine 1 di 2 Dell XPS 18 Touch Control Board Replacement: passo 6, immagine 2 di 2
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Touch Control Board Replacement, Touch Control Board: passo 7, immagine 1 di 2 Dell XPS 18 Touch Control Board Replacement, Touch Control Board: passo 7, immagine 2 di 2
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Touch Control Board Replacement: passo 8, immagine 1 di 2 Dell XPS 18 Touch Control Board Replacement: passo 8, immagine 2 di 2
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Touch Control Board Replacement: passo 9, immagine 1 di 2 Dell XPS 18 Touch Control Board Replacement: passo 9, immagine 2 di 2
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
Conclusione
Altre 4 persone hanno completato questa guida.
Austin Weir
Membro da: 01/31/15
1.287 Reputazione
8 Guide realizzate
Cal Poly, Team 6-29, Amido Winter 2015 Membro di Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Membri
16 Guide realizzate
2 Commenti
It worked perfectly. Thank you.
Kenneth Macdonald - Replica
Which of Torx screwdrivers is used in step 1? As I can see, it is T8, but right above the Introduction section it is stated it is Torx T9...
Евгений Громов - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,928
