Salta al contenuto principale
Dell XPS 18 Left and Right Speakers Replacement
Cosa ti serve
  1. Dell XPS 18 Left and Right Speakers Replacement, Back Cover: passo 1, immagine 1 di 1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Left and Right Speakers Replacement: passo 2, immagine 1 di 1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Left and Right Speakers Replacement: passo 3, immagine 1 di 1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: passo 4, immagine 1 di 2 Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: passo 4, immagine 2 di 2
    • Use the plastic opening tool's angled edge to lift the clasp securing the copper colored volume control cable.
    • Disconnect the volume control cable and pull it back.
  5. Dell XPS 18 Left and Right Speakers Replacement: passo 5, immagine 1 di 1
    • Firmly pull the blue speaker cable loose.
  6. Dell XPS 18 Left and Right Speakers Replacement: passo 6, immagine 1 di 1
    • Remove the two black 4mm screws with a Phillips 00 screwdriver.
  7. Dell XPS 18 Left and Right Speakers Replacement: passo 7, immagine 1 di 1
    • Carefully remove the speaker.
    • To remove the right speaker, follow these same steps.
Conclusione
Austin Weir
Membro da: 01/31/15
1.287 Reputazione
8 Guide realizzate
Cal Poly, Team 6-29, Amido Winter 2015 Membro di Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,285
