Salta al contenuto principale
Dell XPS 17 L702X Hard Drive Replacement
Cosa ti serve
  1. Dell XPS 17 L702X Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Hard Drive Replacement: passo 2, immagine 1 di 2 Dell XPS 17 L702X Hard Drive Replacement: passo 2, immagine 2 di 2
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Hard Drive Replacement: passo 3, immagine 1 di 2 Dell XPS 17 L702X Hard Drive Replacement: passo 3, immagine 2 di 2
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Hard Drive Replacement: passo 5, immagine 1 di 3 Dell XPS 17 L702X Hard Drive Replacement: passo 5, immagine 2 di 3 Dell XPS 17 L702X Hard Drive Replacement: passo 5, immagine 3 di 3
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Hard Drive Replacement: passo 6, immagine 1 di 2 Dell XPS 17 L702X Hard Drive Replacement: passo 6, immagine 2 di 2
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Hard Drive Replacement: passo 7, immagine 1 di 3 Dell XPS 17 L702X Hard Drive Replacement: passo 7, immagine 2 di 3 Dell XPS 17 L702X Hard Drive Replacement: passo 7, immagine 3 di 3
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Hard Drive Replacement: passo 8, immagine 1 di 1
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Hard Drive Replacement: passo 9, immagine 1 di 2 Dell XPS 17 L702X Hard Drive Replacement: passo 9, immagine 2 di 2
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Hard Drive Replacement: passo 10, immagine 1 di 3 Dell XPS 17 L702X Hard Drive Replacement: passo 10, immagine 2 di 3 Dell XPS 17 L702X Hard Drive Replacement: passo 10, immagine 3 di 3
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Hard Drive Replacement: passo 11, immagine 1 di 2 Dell XPS 17 L702X Hard Drive Replacement: passo 11, immagine 2 di 2
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Hard Drive Replacement: passo 12, immagine 1 di 1
    • Remove the hard drive casing.
Conclusione
Altre 6 persone hanno completato questa guida.
Shin Sul
Membro da: 10/02/15
544 Reputazione
3 Guide realizzate
CSU Fullerton, Team 2-6, Bruce Fall 2015 Membro di CSU Fullerton, Team 2-6, Bruce Fall 2015
CSUF-BRUCE-F15S2G6
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 4,341
