Salta al contenuto principale
Dell XPS 15-L502X RAM Replacement
Cosa ti serve
  1. Dell XPS 15-L502X RAM Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the black battery bar from the computer before continuing any further operations.
    • Unscrew the three 5mm Phillps #2 screws on the left side of the back panel.
    Chiedi a FixBot
  2. Dell XPS 15-L502X RAM Replacement: passo 2, immagine 1 di 1
    • Lift up the left side of the panel.
    • There are three tabs holding in the right side of the panel. Pull the panel up and away from these tabs to remove it.
    Chiedi a FixBot
  3. Dell XPS 15-L502X RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Locate both of the RAM slots right behind the back panel.
    Chiedi a FixBot
  4. Dell XPS 15-L502X RAM Replacement: passo 4, immagine 1 di 1
    • Use a black spudger to press the clips holding the RAM outward. You should hear a "click" sound.
    • Once both clips have been released, the RAM will be released at a 45 degree angle.
    Chiedi a FixBot
  5. Dell XPS 15-L502X RAM Replacement: passo 5, immagine 1 di 1
    • Carefully grab the RAM with both hands and pull outward.
    • Repeat steps 4 & 5 to remove the second RAM.
    • Both RAMs should come out without much force. Do not attempt to pull the RAM out with force as this could damage the fixture holding the RAM.
    Chiedi a FixBot
Conclusione
Vishal
Membro da: 09/21/15
778 Reputazione
6 guide realizzate
IUPUI, Team 2-3, Baechle Fall 2015 Membro di IUPUI, Team 2-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G3
3 Membri
8 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 53
Tutti i Tempi: 2,540
