Salta al contenuto principale
Dell XPS 15 L521X WiFi Card Replacement
Cosa ti serve
  1. Dell XPS 15 L521X WiFi Card Replacement, Back Panel: passo 1, immagine 1 di 1
    • Find and remove the two .3cm torx head screws using a T5 screwdriver.
    • Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
  2. Dell XPS 15 L521X WiFi Card Replacement: passo 2, immagine 1 di 1
    • Unplug the battery indicator.
  3. Dell XPS 15 L521X WiFi Card Replacement, WiFi Card: passo 3, immagine 1 di 1
    • Find the .3cm Phillips head screw holding the WiFi Card in place and remove it.
  4. Dell XPS 15 L521X WiFi Card Replacement: passo 4, immagine 1 di 1
    • Gently pull the WiFi card out of its place.
  5. Dell XPS 15 L521X WiFi Card Replacement: passo 5, immagine 1 di 1
    • Gently tug on the two wires connected to the Wifi card
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 686
