Salta al contenuto principale
Dell XPS 15 L521X Hard Drive Replacement
Cosa ti serve
  1. Dell XPS 15 L521X Hard Drive  Replacement, Back Panel: passo 1, immagine 1 di 1
    • Find and remove the two .3cm torx head screws using a T5 screwdriver.
    • Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
  2. Dell XPS 15 L521X Hard Drive  Replacement: passo 2, immagine 1 di 1
    • Unplug the battery indicator.
  3. Dell XPS 15 L521X Hard Drive  Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Find and remove the four .4cm phillips head screws holding the hard drive in place.
  4. Dell XPS 15 L521X Hard Drive  Replacement: passo 4, immagine 1 di 1
    • Gently unplug and remove the hard drive
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
This was a helpful tutorial, except for two small points. #1 - The yellow & red dots on step 1 are reversed; the T5 screws are the six along the two edges of the back panel and the P0 (Phillips #0) screws are under the face plate. #2 - the battery cable should ALWAYS be unplugged for component safety prior to doing any work on a laptop. An additional safety step (though optional) would be to physically remove the battery from the laptop prior to doing any work on it.
ICU Alex - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,208
