Salta al contenuto principale
Dell XPS 15 9570 Wireless Card Replacement
Cosa ti serve
  1. Dell XPS 15 9570 Wireless Card Replacement, Base Cover: passo 1, immagine 1 di 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Wireless Card Replacement: passo 2, immagine 1 di 3 Dell XPS 15 9570 Wireless Card Replacement: passo 2, immagine 2 di 3 Dell XPS 15 9570 Wireless Card Replacement: passo 2, immagine 3 di 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Wireless Card Replacement: passo 3, immagine 1 di 2 Dell XPS 15 9570 Wireless Card Replacement: passo 3, immagine 2 di 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Wireless Card Replacement: passo 4, immagine 1 di 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: passo 5, immagine 1 di 2 Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: passo 5, immagine 2 di 2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  6. Dell XPS 15 9570 Wireless Card Replacement: passo 6, immagine 1 di 1
    • Lift the wireless card bracket off of the wireless card.
  7. Dell XPS 15 9570 Wireless Card Replacement: passo 7, immagine 1 di 2 Dell XPS 15 9570 Wireless Card Replacement: passo 7, immagine 2 di 2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  8. Dell XPS 15 9570 Wireless Card Replacement: passo 8, immagine 1 di 1
    • Carefully remove the wireless card.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 47
Tutti i Tempi: 2,319
