Introduzione
This guide will demonstrate how to replace the speaker of your Dell XPS 15 9570. This may be needed if you have a blown-out or damaged speaker.
Before beginning the repair, be sure the device is powered off and unplugged from the charger.
Cosa ti serve
Flip the device over so the base cover of the computer is facing upwards.
Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
Using the iFixit opening tool, disconnect the speaker cable by pulling it out gently.
Un commento
Thank you for the tutorial!
Just did the swap with speakers form a DELL XPS 15 from an unknown model (most likely wasn't a 9570). Note that these speakers are common inbetween different XPS 15 models (at least XPS 9550 9560 M5510 9350 5520 5510 and Precision 5510 5520 5530 5540 PK23000RP00 TX47W 0TX47W) ******and can be interchanged.
The ones I just used were salvaged from an out-of-service XPS 15 but the parts can be sourced online easily (ex: https://www.amazon.com/Deal4GO-Speaker-R... )
Cheers
