Salta al contenuto principale
Dell XPS 15 9560 Solid State Drive (SSD) Replacement
Cosa ti serve
  1. Dell XPS 15 9560 Solid State Drive (SSD) Replacement, Back Panel: passo 1, immagine 1 di 1
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: passo 2, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: passo 3, immagine 1 di 1
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
  4. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: passo 4, immagine 1 di 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): passo 5, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  6. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: passo 6, immagine 1 di 1
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  7. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: passo 7, immagine 1 di 1
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
Conclusione
Clemson, Team 4-5, Hunter Fall 2021 Membro di Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 39
Tutti i Tempi: 2,850
