Salta al contenuto principale
Dell XPS 15 9560 Motherboard Replacement
Cosa ti serve
  1. Dell XPS 15 9560 Motherboard Replacement, Back Panel: passo 1, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Motherboard Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Motherboard Replacement: passo 3, immagine 1 di 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Motherboard Replacement, Battery: passo 4, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  5. Dell XPS 15 9560 Motherboard Replacement: passo 5, immagine 1 di 1
    • Unplug the battery cable.
  6. Dell XPS 15 9560 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the battery.
  7. Dell XPS 15 9560 Motherboard Replacement, Hard Drive: passo 7, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  8. Dell XPS 15 9560 Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  9. Dell XPS 15 9560 Motherboard Replacement, Solid State Drive (SSD): passo 9, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  10. Dell XPS 15 9560 Motherboard Replacement: passo 10, immagine 1 di 1
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  11. Dell XPS 15 9560 Motherboard Replacement: passo 11, immagine 1 di 1
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
  12. Dell XPS 15 9560 Motherboard Replacement, Wireless Card: passo 12, immagine 1 di 1
    • Using the Phillips #2 screwdriver, remove the single 4.0 mm screw securing the wireless card base to the motherboard.
  13. Dell XPS 15 9560 Motherboard Replacement: passo 13, immagine 1 di 1
    • Disconnect the wireless card cables from the wireless card.
  14. Dell XPS 15 9560 Motherboard Replacement: passo 14, immagine 1 di 1
    • Slide the wireless card out of its slot.
  15. Dell XPS 15 9560 Motherboard Replacement, Fans: passo 15, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove two 4.0 mm screws.
  16. Dell XPS 15 9560 Motherboard Replacement: passo 16, immagine 1 di 1
    • Unplug the fan cable.
  17. Dell XPS 15 9560 Motherboard Replacement: passo 17, immagine 1 di 1
    • Carefully remove the left-side fan.
  18. Dell XPS 15 9560 Motherboard Replacement: passo 18, immagine 1 di 1
  19. Dell XPS 15 9560 Motherboard Replacement: passo 19, immagine 1 di 1
    • Remove the right-side fan.
  20. Dell XPS 15 9560 Motherboard Replacement, RAM: passo 20, immagine 1 di 2 Dell XPS 15 9560 Motherboard Replacement, RAM: passo 20, immagine 2 di 2
    • Pull the metal clips surrounding the RAM stick outward.
    • The RAM will pop out.
    • Remove the RAM stick from the device.
  21. Dell XPS 15 9560 Motherboard Replacement, Motherboard: passo 21, immagine 1 di 1
    • Using a screwdriver, unscrew one 5.0 mm Torx T5 bracket screw.
    • Remove the bracket and unplug and loosen the LCD cable.
  22. Dell XPS 15 9560 Motherboard Replacement: passo 22, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws securing the motherboard to the device.
  23. Dell XPS 15 9560 Motherboard Replacement: passo 23, immagine 1 di 1
    • From right to left, unplug the bottom motherboard cables, DC jack cable, speaker cable.
  24. Dell XPS 15 9560 Motherboard Replacement: passo 24, immagine 1 di 1
    • Remove the motherboard.
Conclusione
Jada Houser
Membro da: 09/28/21
790 Reputazione
7 Guide realizzate
Clemson, Team 4-5, Hunter Fall 2021 Membro di Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 86
Tutti i Tempi: 3,666
