Salta al contenuto principale
Dell XPS 15 9550 Wireless Card Replacement
Cosa ti serve
  1. Dell XPS 15 9550 Wireless Card Replacement, Back/Underside Panel: passo 1, immagine 1 di 1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Wireless Card Replacement: passo 2, immagine 1 di 2 Dell XPS 15 9550 Wireless Card Replacement: passo 2, immagine 2 di 2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Wireless Card Replacement: passo 3, immagine 1 di 3 Dell XPS 15 9550 Wireless Card Replacement: passo 3, immagine 2 di 3 Dell XPS 15 9550 Wireless Card Replacement: passo 3, immagine 3 di 3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 1
    • With a Philips #00 Screwdriver bit, remove one 4 mm long black screw located by the antenna connections on the wireless card.
    • Set the screw and metal holder aside.
  5. Dell XPS 15 9550 Wireless Card Replacement: passo 5, immagine 1 di 2 Dell XPS 15 9550 Wireless Card Replacement: passo 5, immagine 2 di 2
    • Gently lift up each of the antennas (3) to disconnect them from the wireless card.
    • These are similar to a coat button, the antennas snap on and snap off.
  6. Dell XPS 15 9550 Wireless Card Replacement: passo 6, immagine 1 di 3 Dell XPS 15 9550 Wireless Card Replacement: passo 6, immagine 2 di 3 Dell XPS 15 9550 Wireless Card Replacement: passo 6, immagine 3 di 3
    • With the antennas disconnected, gently pull the wireless card out at the angle it sits at.
    • The wireless card has been successfully removed!
Conclusione
Altre 4 persone hanno completato questa guida.
UW Stout, Team S6-G1, Ogden Fall 2018 Membro di UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Membri
23 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 76
Tutti i Tempi: 9,574
