Salta al contenuto principale
Dell XPS 15 9550 Solid State Drive Replacement
Cosa ti serve
  1. Dell XPS 15 9550 Solid State Drive Replacement, Back/Underside Panel: passo 1, immagine 1 di 1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Solid State Drive Replacement: passo 2, immagine 1 di 2 Dell XPS 15 9550 Solid State Drive Replacement: passo 2, immagine 2 di 2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Solid State Drive Replacement: passo 3, immagine 1 di 3 Dell XPS 15 9550 Solid State Drive Replacement: passo 3, immagine 2 di 3 Dell XPS 15 9550 Solid State Drive Replacement: passo 3, immagine 3 di 3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 Solid State Drive Replacement, Solid State Drive: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the SSD screw.
  5. Dell XPS 15 9550 Solid State Drive Replacement: passo 5, immagine 1 di 2 Dell XPS 15 9550 Solid State Drive Replacement: passo 5, immagine 2 di 2
    • Gently remove the SSD.
Conclusione
Zach Jones
Membro da: 03/25/22
400 Reputazione
2 Guide realizzate
IUPUI, Team 2-4, Harley Spring 2022 Membro di IUPUI, Team 2-4, Harley Spring 2022
IUPUI-HARLEY-S22S2G4
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,403
