Salta al contenuto principale
Dell XPS 15 9550 RAM Replacement
Cosa ti serve
  1. Dell XPS 15 9550 RAM Replacement, Back/Underside Panel: passo 1, immagine 1 di 1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 RAM Replacement: passo 2, immagine 1 di 2 Dell XPS 15 9550 RAM Replacement: passo 2, immagine 2 di 2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 RAM Replacement: passo 3, immagine 1 di 3 Dell XPS 15 9550 RAM Replacement: passo 3, immagine 2 di 3 Dell XPS 15 9550 RAM Replacement: passo 3, immagine 3 di 3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 RAM Replacement, RAM: passo 4, immagine 1 di 2 Dell XPS 15 9550 RAM Replacement, RAM: passo 4, immagine 2 di 2
    • There are 2 separate RAM sticks.
    • Gently push down on the 2 outside tabs of the RAM stick you want to replace.
    • While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
  5. Dell XPS 15 9550 RAM Replacement: passo 5, immagine 1 di 2 Dell XPS 15 9550 RAM Replacement: passo 5, immagine 2 di 2
    • Firmly grasp the RAM stick from the flipped up edge and gently pull out, to release the RAM stick.
Conclusione
Altre 6 persone hanno completato questa guida.
jbaseballin2
Membro da: 10/04/18
123 Reputazione
1 Guida realizzata
UW Stout, Team S6-G1, Ogden Fall 2018 Membro di UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Membri
23 Guide realizzate
1Commento della guida
What type ram do you replace it with? Could you post a link?
twrfan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 47
Tutti i Tempi: 9,280
