Introduzione
How to replace the memory modules of a Dell XPS 15 9530.
Parti
Nessuna parte richiesta.
  1. After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • Don't forget to unscrew the two screws hidden under the system badge!
  2. Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
    • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
    • Remove the screws that secure the battery to the palm-rest assembly.
      • Disconnect the battery cable from the system board.
        • Lift the battery off the palm-rest assembly.
        • After you remove the battery, turn the computer over, open the display, and press the power button for about five seconds to ground the system board.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module connector until the memory module pops up.
      • Remove the memory module from the memory-module connector.
    • Align the notch on the New memory module with the tab on the memory-module connector.
      • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
      • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Conclusione
To reassemble your device, put the battery back in and reaffix the base-cover assembly to the system.
Johnathan Hammond
Membro da: 28/02/2018
35.878 Reputazione
408 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 122
