Salta al contenuto principale
Dell XPS 15 9530 Base-Cover Assembly Replacement
Cosa ti serve
  1. Dell XPS 15 9530 Base-Cover Assembly Replacement, Unscrewing the Base-Cover Assembly: passo 1, immagine 1 di 1
    • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • Don't forget to unscrew the two screws hidden under the system badge!
  2. Dell XPS 15 9530 Base-Cover Assembly Replacement, Prying Off the Base-Cover Assembly: passo 2, immagine 1 di 1
    • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
Conclusione
Un commento
I need to replace these screws. What is the size, dimension, type?
Jason Benci - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 520
