Salta al contenuto principale
Dell XPS 15 9510 Rear Panel Replacement
Cosa ti serve
  1. Dell XPS 15 9510 Rear Panel Replacement, Rear Panel: passo 1, immagine 1 di 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Rear Panel Replacement: passo 2, immagine 1 di 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Rear Panel Replacement: passo 3, immagine 1 di 1
    • Lift the back panel of the laptop off and set it aside.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,106
