Salta al contenuto principale
Dell XPS 15 9500 Fan Replacement
Cosa ti serve
  1. Dell XPS 15 9500 Fan Replacement, Base Panel: passo 1, immagine 1 di 1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 Fan Replacement: passo 2, immagine 1 di 2 Dell XPS 15 9500 Fan Replacement: passo 2, immagine 2 di 2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 Fan Replacement, Fan: passo 3, immagine 1 di 2 Dell XPS 15 9500 Fan Replacement, Fan: passo 3, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two 4.0 mm screws screws from each fan (four screws total).
  4. Dell XPS 15 9500 Fan Replacement: passo 4, immagine 1 di 1
    • Use an opening tool to push the left fan cable plug out of its socket.
    • Repeat for right fan cable.
  5. Dell XPS 15 9500 Fan Replacement: passo 5, immagine 1 di 1
    • Lift the fan up and away from the heatsink.
    • Repeat for the right fan.
Conclusione
Bryan Chung
Membro da: 10/18/19
437 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 60
Tutti i Tempi: 1,473
