Salta al contenuto principale
Dell XPS 14Z L412Z LCD Screen Glass Replacement
Cosa ti serve
  1. Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: passo 1, immagine 1 di 2 Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: passo 1, immagine 2 di 2
    • Using the iFixit opening tools, carefully pry up the trim around the screen.
    • It is recommended to start in a corner.
  2. Dell XPS 14Z L412Z LCD Screen Glass Replacement: passo 2, immagine 1 di 2 Dell XPS 14Z L412Z LCD Screen Glass Replacement: passo 2, immagine 2 di 2
    • Using a heat gun, carefully apply heat evenly across the glass.
  3. Dell XPS 14Z L412Z LCD Screen Glass Replacement: passo 3, immagine 1 di 2 Dell XPS 14Z L412Z LCD Screen Glass Replacement: passo 3, immagine 2 di 2
    • Using the iFixit opening tools, carefully pry the glass off the screen.
    • This is glass and will shatter if too much force is used.
Conclusione
UW Stout, Team S8-G3, Ogden Spring 2018 Membro di UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Membri
6 Guide realizzate
Un commento
to remove the black cover, use the rod of a pen pen cap. Spread both sides while pressing the top of the black cover (towards the inside of the screen). Must a little force.The closure mechanism is composed of two things that alternate every 2 cm: 1 clips that is sinking on the gray part (you have to lift the black part towards the right to take it out) then 1 rod that comes down in underneath (just stand aside - neither lift nor lower to remove)
wiwi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,122
