Salta al contenuto principale
Dell XPS 14Z L412Z Hard Drive Replacement
Cosa ti serve
  1. Dell XPS 14Z L412Z Hard Drive Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z Hard Drive Replacement: passo 2, immagine 1 di 2 Dell XPS 14Z L412Z Hard Drive Replacement: passo 2, immagine 2 di 2
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 2 Dell XPS 14Z L412Z Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 2
    • Locate the hard drive on the bottom right corner.
    • Unscrew the three 3.5mm screws with the Phillips #0 screwdriver.
  4. Dell XPS 14Z L412Z Hard Drive Replacement: passo 4, immagine 1 di 1
    • Remove the four additional 3.5mm screws using the Phillips #0 screwdriver.
  5. Dell XPS 14Z L412Z Hard Drive Replacement: passo 5, immagine 1 di 1
    • Carefully pull and remove the old hard drive.
Conclusione
UW Stout, Team S8-G3, Ogden Spring 2018 Membro di UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Membri
6 Guide realizzate
Un commento
On my laptop there was a small curved metal bracket that sat in the very corner of the PC covering one corner of the hard drive. That had to be removed by loosening a screw and gently prying the bar out before the hard drive could be removed.
dude - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,537
