Introduzione
The battery is the main power supply to the laptop. Keeping a healthy battery is good for your device's health. A worn out battery can cause overheating of the device and it will have a shorter battery life. The removal of the battery is fairly simple and this guide will show you how to remove it. You will need a plastic opening tool and a Phillips #0 screwdriver.
Parti
Nessuna parte richiesta.
  1. Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Using the plastic opening tool, pry up the back cover. It is recommended to start from a corner and run the tool along the edge of the cover.
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. The battery is on the bottom left side.
    • The battery is on the bottom left side.
  5. Unscrew the five 4.5mm Phillips #0 screws around the battery.
    • Unscrew the five 4.5mm Phillips #0 screws around the battery.
  6. Using the plastic opening tools, carefully unplug the battery connection. Then, plug your replacement battery into the new connection.
    • Using the plastic opening tools, carefully unplug the battery connection.
    • Then, plug your replacement battery into the new connection.
Conclusione
Altre 3 persone hanno completato questa guida.
Colton Niewolny
Membro da: 15/02/2018
403 Reputazione
4 Guide realizzate
UW Stout, Team S8-G3, Ogden Spring 2018 Membro di UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Membri
6 Guide realizzate
It worked smoothly! Less than 15 minutes. I used a OEM-battery, instead of an original one.
Jean Wallemacq - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 54
Tutti i Tempi: 497
