Salta al contenuto principale
Dell XPS 14Z L412Z Battery Replacement
Cosa ti serve
  1. Dell XPS 14Z L412Z Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z Battery Replacement: passo 2, immagine 1 di 2 Dell XPS 14Z L412Z Battery Replacement: passo 2, immagine 2 di 2
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z Battery Replacement, Battery: passo 3, immagine 1 di 1
    • The battery is on the bottom left side.
  4. Dell XPS 14Z L412Z Battery Replacement: passo 4, immagine 1 di 1
    • Unscrew the five 4.5mm Phillips #0 screws around the battery.
  5. Dell XPS 14Z L412Z Battery Replacement: passo 5, immagine 1 di 2 Dell XPS 14Z L412Z Battery Replacement: passo 5, immagine 2 di 2
    • Using the plastic opening tools, carefully unplug the battery connection.
    • Then, plug your replacement battery into the new connection.
Conclusione
Altre 4 persone hanno completato questa guida.
UW Stout, Team S8-G3, Ogden Spring 2018 Membro di UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Membri
6 Guide realizzate
Un commento
It worked smoothly! Less than 15 minutes. I used a OEM-battery, instead of an original one.
Jean Wallemacq - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,925
