Introduzione
To open up the Dell XPS 14Z L412Z, one will need to first remove the back panel. This is a relatively simple and safe procedure. One place where care is necessary is around the I/O ports. The back panel provides the initial shell for these ports. Be careful not to damage these ports while pulling the panel. You will need one tweezers, a Phillips #0 screwdriver, and a plastic opening tool.
Cosa ti serve
Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
