Introduzione
Hard drives can sometimes experience hardware failure and need to be replaced, or you may just want to upgrade. This guide will show you how to remove the hard drive from the laptop and detach the cosmetic cover to replace the hard drive.
Cosa ti serve
Locate the spring latch on the bottom of the device that will unlatch the battery.
Hold the spring latch in the open position and pull the battery out of its recess.
Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
Pull the panel upwards and towards the battery to remove.
Put the panel to the side, exposing the RAM.
Use a JIS 1 screwdriver to remove (2) 2.5mm screws located on the right side of the RAM bay.
