Salta al contenuto principale
Dell XPS 1340 CPU Fan Replacement
Cosa ti serve
  1. Dell XPS 1340 CPU Fan Replacement, CPU Fan: passo 1, immagine 1 di 1
    • Remove the battery by sliding the battery lock switch
  2. Dell XPS 1340 CPU Fan Replacement: passo 2, immagine 1 di 1
    • Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
  3. Dell XPS 1340 CPU Fan Replacement: passo 3, immagine 1 di 1
    • Remove two screws which holds a smaller back panel covering only the heatsink
  4. Dell XPS 1340 CPU Fan Replacement: passo 4, immagine 1 di 2 Dell XPS 1340 CPU Fan Replacement: passo 4, immagine 2 di 2
    • Loosen the four screws on the heat sink for the CPU. Note that these screws don't come out.
    • Now carefully lift the unit from holding the heat pipe.
    • After the heat-pipe unit is removed, the power connector for the fan is accessible.
  5. Dell XPS 1340 CPU Fan Replacement: passo 5, immagine 1 di 2 Dell XPS 1340 CPU Fan Replacement: passo 5, immagine 2 di 2
    • First remove the power connector for the CPU Fan.
    • Now remove the two screws connecting the CPU Fan.
    • Slowly slide the CPU Fan upwards. It would be a little tight around the edges.
  6. Dell XPS 1340 CPU Fan Replacement: passo 6, immagine 1 di 1
    • Unpack the new fan. Make sure the power wires are fixed in the hook provided.
    • Follow all step backwards and finish.
Conclusione
Altre 4 persone hanno completato questa guida.
Paras Tolani
Membro da: 03/01/13
188 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,806
