Introduzione
How to replace the mSata SSD drive in a Dell XPS 13 L322X laptop. The images and information in this guide were taken from this computer's service manual, which can be found on the product page.
Parti
Nessuna parte richiesta.
  1. After turning off the computer, use a Torx 5 screwdriver to remove the 10 screws (#2) from the computer's base.
    • After turning off the computer, use a Torx 5 screwdriver to remove the 10 screws (#2) from the computer's base.
    • Using a prying tool or a fingernail, lift up the base cover (#1).
  2. Lift up the small latch which holds down the power-light board cable (#3) down. Remove the cable by pulling out sideways.
    • Lift up the small latch which holds down the power-light board cable (#3) down. Remove the cable by pulling out sideways.
    • After removing the Philips screw which holds down the power-light board (#1), remove the power light board (#2) and its cable.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Peel the tape that is adhered over the solid-state drive.
    • Peel the tape that is adhered over the solid-state drive.
  5. Remove the screw that secures the solid-state drive to the system board.
    • Remove the screw that secures the solid-state drive to the system board.
    • Slide and remove the solid-state drive out of the system-board connector.
  6. Align the notch on the NEW solid-state drive with the tab in the system-board connector.
    • Align the notch on the NEW solid-state drive with the tab in the system-board connector.
    • CAUTION: Use firm and even pressure to slide the solid-state drive into place. If you use excessive force, you may damage the connector.
    • Insert the solid-state drive connector at a 45-degree angle into the system-board connector.
    • Replace the screw that secures the solid-state drive to the system board.
  7. Adhere the tape over the solid-state drive.
    • Adhere the tape over the solid-state drive.
Conclusione
To reassemble your device, reattatch the power board cable and screw back on the base cover.
Johnathan Hammond
Membro da: 28/02/2018
35.786 Reputazione
408 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 354
