Salta al contenuto principale
Dell XPS 13 L322X Battery Replacement
Cosa ti serve
  1. Dell XPS 13 L322X Battery Replacement, Base Plate: passo 1, immagine 1 di 1
    • Shut down and unplug the device before beginning.
    • Use a Torx T5 screwdriver to remove the 10 screws from the computer's base plate.
    • Use a prying tool or a fingernail to lift up and remove the base cover.
  2. Dell XPS 13 L322X Battery Replacement, Battery: passo 2, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove all of the screws securing the battery.
    • Use a spudger to lift the edge of the battery, then carefully remove it.
Conclusione
To reassemble your device, after the new battery has been put in place, screw all 10 screws back on the base cover.
Johnathan Hammond
Membro da: 02/28/18
45.034 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.987 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 27
Tutti i Tempi: 2,865
