Salta al contenuto principale
Dell XPS 13 L321X Mouse pad Replacement
Cosa ti serve
  1. Dell XPS 13 L321X Mouse pad Replacement, Track Pad: passo 1, immagine 1 di 2 Dell XPS 13 L321X Mouse pad Replacement, Track Pad: passo 1, immagine 2 di 2
    • Remove ten 3mm screws from the back cover with a T5 screwdriver.
  2. Dell XPS 13 L321X Mouse pad Replacement: passo 2, immagine 1 di 2 Dell XPS 13 L321X Mouse pad Replacement: passo 2, immagine 2 di 2
    • Disconnect the ribbon cable with a plastic iFixit opening tool, by lifting up the black clip and by pulling the white ribbon off.
    • Pull aside the ribbon cable.
  3. Dell XPS 13 L321X Mouse pad Replacement: passo 3, immagine 1 di 1
    • With a plastic iFixit opeing tool, insert it in between and remove the battery cable.
  4. Dell XPS 13 L321X Mouse pad Replacement: passo 4, immagine 1 di 2 Dell XPS 13 L321X Mouse pad Replacement: passo 4, immagine 2 di 2
    • Use a PH00 size screwdriver to remove the 8 screws that secure the battery.
    • Six 3mm screws.
    • Two 5mm screws.
    • Lift the battery out.
  5. Dell XPS 13 L321X Mouse pad Replacement: passo 5, immagine 1 di 1
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and by pulling the white ribbon.
    • Place aside.
  6. Dell XPS 13 L321X Mouse pad Replacement: passo 6, immagine 1 di 3 Dell XPS 13 L321X Mouse pad Replacement: passo 6, immagine 2 di 3 Dell XPS 13 L321X Mouse pad Replacement: passo 6, immagine 3 di 3
    • Remove four 2mm screws with a PH00 screwdriver.
    • Remove the mouse pad.
Linea Traguardo
USF Tampa, Team S6-G3, Lacy Spring 2017 Membro di USF Tampa, Team S6-G3, Lacy Spring 2017
USFT-LACY-S17S6G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 797
