Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
If your Dell XPS 13 (also known as Dell XPS 13 Infinity Edge Ultrabook or Dell XPS 13 Skylake) has lost its ability to hold a charge, you most likely have a dead battery, which requires replacement.
A functional battery provides power to your laptop. Eventually, laptop batteries will rapidly drain after going through a repeated amount of charge cycles. If you notice that your charged battery is draining more quickly than usual, consider calibrating your battery to determine an accurate charging capacity. If you continue to notice significant drops in battery percentage, you should replace your battery.
A punctured battery can cause a dangerous fire. If your battery is swollen, take appropriate precautions.
Make sure to power down your device before you begin.
  1. Remove the eight 4 mm T5 Torx screws from the bottom cover. Remove the eight 4 mm T5 Torx screws from the bottom cover.
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Use a plastic opening tool to pry open the 'XPS' flap in the middle. Use a plastic opening tool to pry open the 'XPS' flap in the middle.
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Remove the single Phillips screw hidden beneath the flap.
    • Remove the single Phillips screw hidden beneath the flap.
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  6. Remove the bottom cover.
    • Remove the bottom cover.
  7. Pull the battery cable connector towards the battery to disconnect it from its socket.
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  8. Remove three Phillips screws labeled "M2x2"
    • Remove three Phillips screws labeled "M2x2"
    • Remove a Phillips screw labeled "M1.6x4"
  9. Peel up any tape securing the speaker cables to the battery.
    • Peel up any tape securing the speaker cables to the battery.
    • You don't need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  10. Remove the battery.
    • Remove the battery.
Conclusione
Altre 115 persone hanno completato questa guida.
The Raptor
Membro da: 27/11/2016
5.622 Reputazione
6 Guide realizzate
Put compatible batteries under parts.
Keenan Lewis - Replica
Awesome instructions. Worked perfectly. I’m back in business now, and it took me about 10 minutes. Thank you so much. By the way, I was using iFixit tools, which really helped. John Day
John Day - Replica
using picks to open the case was a little tricky, but without this guide I would have looking for more screws or other ways to open it!
Mark - Replica
I followed the instruction carefully and it was quite helpful. However, now that I am done with the battery replacement, the speaker no longer works, and it seems that there is a hardware issue. Any thoughts on this?
Sara Hadavi - Replica
@Sara - Looking on another ifixit procedure, I found that the speaker wires are taped to the battery, so I suspect that the speaker was not properly plugged in after reassemble, or that something happened to the wires during battery removal. Hopefully the wires weren’t cut or stretched.
Here is what the XPS 13 teardown procedure had to say:
“….After that, it still isn't a perfectly clean getaway—the speaker wires are strategically taped to the battery in a half dozen spots, which we'll have to liberate to free the battery. (Admittedly, it could have been a lot worse.)
These same wires are trapped under the battery screws—so speaker replacement means battery removal. It looks like the XPS has some layering issues.”
ref: Dell XPS 13 Teardown
I hope this helps.
Graham Vodden -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 174
Ultimi 7 Giorni: 1,204
Ultimi 30 Giorni: 5,921
Tutti i Tempi: 136,771
