Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will explain how to replace the back cover of the Dell XPS 13.
  1. Remove the eight 4 mm T5 Torx screws from the bottom cover. Remove the eight 4 mm T5 Torx screws from the bottom cover.
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Use a plastic opening tool to pry open the 'XPS' flap in the middle. Use a plastic opening tool to pry open the 'XPS' flap in the middle.
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Remove the single Phillips screw hidden beneath the flap.
    • Remove the single Phillips screw hidden beneath the flap.
  4. Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Remove the bottom cover.
    • Remove the bottom cover.
Conclusione
Altre 3 persone hanno completato questa guida.
Ella Herrmann
Membro da: 24/04/2017
1.366 Reputazione
3 Guide realizzate
Cal Poly, Team S21-G6, Livingston Spring 2017 Membro di Cal Poly, Team S21-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G6
5 Membri
24 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 136
Ultimi 30 Giorni: 547
Tutti i Tempi: 11,520
