Salta al contenuto principale
Dell XPS 13 9365 2-in-1 Display Assembly Replacement
Cosa ti serve
  1. Dell XPS 13 9365 2-in-1 Display Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 2, immagine 1 di 1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 3, immagine 1 di 1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 7, immagine 1 di 1
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Display Assembly Replacement, Display Assembly: passo 8, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x2.5) that secures the wireless-card bracket to the motherboard.
  9. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 9, immagine 1 di 1
    • Lift the wireless-card bracket off the wireless card.
  10. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 10, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of nylon tipped tweezers to gently disconnect the antenna cables from the wireless card.
  11. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 11, immagine 1 di 1
    • Peel off the tape that secures the display cable to the M.2 solid-state drive heatsink.
  12. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 12, immagine 1 di 2 Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 12, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x2.5) that secure the display cable bracket to the motherboard.
    • Lift the display cable bracket off the display cable.
  13. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 13, immagine 1 di 1
    • Use the pull tab to disconnect the display cable from the motherboard.
  14. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 14, immagine 1 di 1
    • Disconnect the touch-screen cable from the system board (labeled "TS").
  15. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 15, immagine 1 di 1
    • Disconnect the camera cable from the system board.
  16. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 16, immagine 1 di 3 Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 16, immagine 2 di 3 Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 16, immagine 3 di 3
    • Open the palm-rest assembly fully and place the display assembly and palm-rest assembly face down.
    • Make sure that your surface is flat and free of objects when you lay the laptop face down.
    • Use a Phillips #000 screwdriver to remove the six screws (M2.5x3.5) that secure the display hinges to the palm-rest assembly. There are three on each side.
  17. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: passo 17, immagine 1 di 1
    • Lift the display assembly off the palm-rest assembly.
Conclusione
1Commento della guida
how to disassembly hinge for replace the video cable?
Logan Solo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,250
