Salta al contenuto principale
Introduzione
This guide show the procedure for replacing the display of the Dell XPS 13 1950. It requires opening the back case and removing the battery and speakers. The display is hooked up to the motherboard by six separate connectors, and cannot be removed unless the laptop is open. Use this guide if have a cracked or malfunctioning Dell XPS 13 1950 display.
  1. Remove the eight 4 mm T5 Torx screws from the bottom cover. Remove the eight 4 mm T5 Torx screws from the bottom cover.
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Use a plastic opening tool to pry open the central flap. Remove the single Phillips #0 screw beneath the flap in the center of the bottom panel.
    • Use a plastic opening tool to pry open the central flap.
    • Remove the single Phillips #0 screw beneath the flap in the center of the bottom panel.
  3. Lift up the back cover using both hands.
    • Lift up the back cover using both hands.
  4. Remove the four 3 mm Phillips #0 screws located on each corner of the battery. Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  5. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  6. Pull the battery cable connector towards the battery to disconnect it from its socket. Pull the battery cable connector towards the battery to disconnect it from its socket.
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
  7. Peel up any tape securing the speaker cables to the battery.
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  8. Use your hands to gently lift up the battery. This image includes the removal of the speakers, which is not necessary, only the tape must be peeled up to allow removing the battery.
    • Use your hands to gently lift up the battery.
    • This image includes the removal of the speakers, which is not necessary, only the tape must be peeled up to allow removing the battery.
  9. Pull the sliding touchscreen connector gently to the right and out of the motherboard. Pull the sliding touchscreen connector gently to the right and out of the motherboard. Pull the sliding touchscreen connector gently to the right and out of the motherboard.
    • Pull the sliding touchscreen connector gently to the right and out of the motherboard.
  10. Use your fingers to remove the sliding camera connector out from the motherboard. Use your fingers to remove the sliding camera connector out from the motherboard.
    • Use your fingers to remove the sliding camera connector out from the motherboard.
  11. Pop the coaxial antenna cables up from the wireless card with the flat end of the spudger. Pop the coaxial antenna cables up from the wireless card with the flat end of the spudger.
    • Pop the coaxial antenna cables up from the wireless card with the flat end of the spudger.
  12. Using a spudger, pry up the press fit connector on the end of the left cable bundle. Gently remove the sliding cable connector from its port to the left of the fan. Gently remove the sliding cable connector from its port to the left of the fan.
    • Using a spudger, pry up the press fit connector on the end of the left cable bundle.
    • Gently remove the sliding cable connector from its port to the left of the fan.
  13. Remove the four, black 4.6 mm screws from the display mounts using a Phillips #0 screwdriver. The laptop needs to be open for the display to clear the cutouts of the bottom case, so you may find it easier to remove the screws while already in an open configuration. Remove the display assembly.
    • Remove the four, black 4.6 mm screws from the display mounts using a Phillips #0 screwdriver.
    • The laptop needs to be open for the display to clear the cutouts of the bottom case, so you may find it easier to remove the screws while already in an open configuration.
    • Remove the display assembly.
Conclusione
Austin Blakely
Membro da: 11/03/2019
1.917 Reputazione
15 Guide realizzate
iFixit Membro di iFixit
Community
99 Membri
9.276 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 61
Tutti i Tempi: 248
