Salta al contenuto principale
Dell XPS 12 9Q33 mSATA Card Replacement
Cosa ti serve
  1. Dell XPS 12 9Q33 mSATA Card Replacement, Removing the Battery: passo 1, immagine 1 di 1
    • Slide the battery cable connector out of its system board socket.
    • Pull parallel to the motherboard, not straight up, or you will damage the socket.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Lift and remove the battery along with its cable.
    • Slide and hold the power switch for about five seconds to ground the system board.
  2. Dell XPS 12 9Q33 mSATA Card Replacement, Removing the mSATA card: passo 2, immagine 1 di 1
    • Remove the screw that secures the mSATA card to the system board.
    • Slide and remove the mSATA card out of the mSATA-card connector.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Conclusione
Altre 3 persone hanno completato questa guida.
Johnathan Hammond
Membro da: 02/28/18
44.820 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 368
