Salta al contenuto principale
Dell XPS 12 9250 Solid-State Drive Replacement
Cosa ti serve
  1. Dell XPS 12 9250 Solid-State Drive Replacement, Removing the Back Cover: passo 1, immagine 1 di 2 Dell XPS 12 9250 Solid-State Drive Replacement, Removing the Back Cover: passo 1, immagine 2 di 2
    • Turn the tablet over.
    • Remove the screws that secure the back-cover assembly to the display assembly.
    • Using a plastic scribe, pry up along the edges of the back-cover assembly.
    • Carefully, lift the back-cover assembly and turn it over.
  2. Dell XPS 12 9250 Solid-State Drive Replacement, Removing the Battery: passo 2, immagine 1 di 1
    • Remove the screws that secure the battery to the back-cover assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery, along with its cable, off the back-cover assembly.
  3. Dell XPS 12 9250 Solid-State Drive Replacement, Removing M.2 SSD: passo 3, immagine 1 di 1
    • Remove the screw that secures the solid-state drive to the back-cover assembly.
    • Lift and slide the solid-state drive off the back-cover assembly.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Linea Traguardo
Johnathan Hammond
Membro da: 02/28/18
44.830 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,471
