Salta al contenuto principale
Dell XPS 10 USB Port Replacement
Cosa ti serve
  1. Dell XPS 10 USB Port Replacement, Battery: passo 1, immagine 1 di 3 Dell XPS 10 USB Port Replacement, Battery: passo 1, immagine 2 di 3 Dell XPS 10 USB Port Replacement, Battery: passo 1, immagine 3 di 3
    • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
    • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
    • Finally, slide the two plastic opening tools all around the case until it is open.
  2. Dell XPS 10 USB Port Replacement: passo 2, immagine 1 di 3 Dell XPS 10 USB Port Replacement: passo 2, immagine 2 di 3 Dell XPS 10 USB Port Replacement: passo 2, immagine 3 di 3
    • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
    • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
    • Unplug the connector the connects the battery to the mother board.
    • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
  3. Dell XPS 10 USB Port Replacement, USB Port: passo 3, immagine 1 di 3 Dell XPS 10 USB Port Replacement, USB Port: passo 3, immagine 2 di 3 Dell XPS 10 USB Port Replacement, USB Port: passo 3, immagine 3 di 3
    • Use the plastic opening tools to lift up the black cable shown in the picture.
    • Slide one end of the speaker to the other side and the speaker will be out.
  4. Dell XPS 10 USB Port Replacement: passo 4, immagine 1 di 3 Dell XPS 10 USB Port Replacement: passo 4, immagine 2 di 3 Dell XPS 10 USB Port Replacement: passo 4, immagine 3 di 3
    • Unscrew the shown screw in the picture.
    • Remove the silver tape using the plastic tool as shown in the picture.
    • Note: be careful when removing the tape as it is fragile.
  5. Dell XPS 10 USB Port Replacement: passo 5, immagine 1 di 3 Dell XPS 10 USB Port Replacement: passo 5, immagine 2 di 3 Dell XPS 10 USB Port Replacement: passo 5, immagine 3 di 3
    • Unscrew the three screws shown in the picture.
    • 3 mm screws.
    • Slide the small piece shown in green square on both black pieces and lift them up using the plastic tool as shown in the picture.
    • Finally, take the USB port out. You will have three pieces out: the port and the two black pieces as shown in the picture.
Conclusione
James
Membro da: 10/04/16
401 Reputazione
3 Guide realizzate
USF Tampa, Team 2-1, Nance Fall 2016 Membro di USF Tampa, Team 2-1, Nance Fall 2016
USFT-NANCE-F16S2G1
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,825
