Salta al contenuto principale
Dell XPS 10 Battery Replacement
Cosa ti serve
  1. Dell XPS 10 Battery Replacement, Battery: passo 1, immagine 1 di 3 Dell XPS 10 Battery Replacement, Battery: passo 1, immagine 2 di 3 Dell XPS 10 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
    • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
    • Finally, slide the two plastic opening tools all around the case until it is open.
  2. Dell XPS 10 Battery Replacement: passo 2, immagine 1 di 3 Dell XPS 10 Battery Replacement: passo 2, immagine 2 di 3 Dell XPS 10 Battery Replacement: passo 2, immagine 3 di 3
    • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
    • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
    • Unplug the connector the connects the battery to the mother board.
    • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
Conclusione
Altre 2 persone hanno completato questa guida.
saraspam
Membro da: 09/28/16
244 Reputazione
2 Guide realizzate
USF Tampa, Team 2-1, Nance Fall 2016 Membro di USF Tampa, Team 2-1, Nance Fall 2016
USFT-NANCE-F16S2G1
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 3,149
