Salta al contenuto principale
Dell Vostro V130 LED Cover Replacement
Cosa ti serve
  1. Dell Vostro V130 LED Cover Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro V130 LED Cover Replacement, Removing the Base Cover: passo 2, immagine 1 di 1
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro V130 LED Cover Replacement, Disconnecting the Battery: passo 3, immagine 1 di 1
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Dell Vostro V130 LED Cover Replacement, Remove Battery Screws: passo 4, immagine 1 di 1
    • Remove the screws that secure the battery to the computer.
  5. Dell Vostro V130 LED Cover Replacement, Lift the Battery: passo 5, immagine 1 di 1
    • Lift the battery up and away from the computer.
  6. Dell Vostro V130 LED Cover Replacement, LED Cover: passo 6, immagine 1 di 1
    • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
  7. Dell Vostro V130 LED Cover Replacement, Removing the LED Cover: passo 7, immagine 1 di 1
    • Pull the LED cover toward the keyboard and remove it from the computer.
Linea Traguardo
Johnathan Hammond
Membro da: 02/28/18
44.830 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 127
