Salta al contenuto principale
Introduzione
In this guide, we will be showing you how to remove the Hard Drive and Audio Board.
Parti
Nessuna parte specificata.
  1. Remove the screws that secure the base cover to the computer.
    • Remove the screws that secure the base cover to the computer.
  2. Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Remove the screws that secure the battery to the computer.
    • Remove the screws that secure the battery to the computer.
  5. Kit di riparazione per Android
    A new screen or battery is one kit away.
    Acquista ora
    Acquista ora
  6. Lift the battery up and away from the computer.
    • Lift the battery up and away from the computer.
  7. Disconnect the speaker and system board cables from the audio board.
    • Disconnect the speaker and system board cables from the audio board.
  8. Remove the screws that secure the audio board and the hard drive to the computer.
    • Remove the screws that secure the audio board and the hard drive to the computer.
  9. Lift and remove the hard drive and audio board assembly from the computer.
    • Lift and remove the hard drive and audio board assembly from the computer.
  10. Slide the audio board from the hard drive.
    • Slide the audio board from the hard drive.
  11. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  12. Remove the hard drive from the hard-drive bracket.
    • Remove the hard drive from the hard-drive bracket.
Linea Traguardo
Johnathan Hammond
Membro da: 28/02/2018
36.179 Reputazione
408 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
926 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 216
