Salta al contenuto principale
Introduzione
You can follow these steps to replace the sound card in your Dell Vostro V13. Be sure to power down, unplug and also back-up your laptop in order to prevent injury and loss of data.
Parti
Nessuna parte specificata.
  1. Back up the memory to an external drive and power off the laptop before starting. Flip the laptop over so the vents are facing you. Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Slide out the SD and MicroSD holders. If you are having trouble sliding them out, use the plastic opening tool. If you are having trouble sliding them out, use the plastic opening tool.
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Slide the plastic opening tool around the perimeter of the laptop until the cover pops off. Pull the back cover off. Pull the back cover off.
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Remove the three black 3.9 mm Phillips #1 screws holding the battery in place. Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Kit di riparazione per Android
    A new screen or battery is one kit away.
    Acquista ora
    Acquista ora
  6. Flip up the clip of the ribbon connector. Pull the strip out to disconnect the battery. Pull the strip out to disconnect the battery.
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  7. Remove the battery. Removing the battery allows you to work safely.
    • Remove the battery.
    • Removing the battery allows you to work safely.
  8. Remove the black 3.0 mm Phillips #1 screw. Remove the two 5.1 mm silver Phillips #1 screws.
    • Remove the black 3.0 mm Phillips #1 screw.
    • Remove the two 5.1 mm silver Phillips #1 screws.
  9. Disconnect the white plug on the top left corner of the sound card. Disconnect the white plug on the top left corner of the sound card.
    • Disconnect the white plug on the top left corner of the sound card.
  10. Use the plastic opening tool to flip the ribbon connector up. Use the plastic opening tool to flip the ribbon connector up.
    • Use the plastic opening tool to flip the ribbon connector up.
  11. Pull the sound card out of the laptop. Pull the sound card out of the laptop.
    • Pull the sound card out of the laptop.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 63
