Introduzione
Batteries slowly lose their ability to hold charge over time. If your battery will not charge or hold a charge, please refer to the Troubleshooting Page. If the problem persists, replace the battery by following the steps below. Make sure your laptop is turned off before starting this guide.
Cosa ti serve
Flip the laptop over so the vents are facing you.
Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
